Swap from side to side. No point in throwing out part worn parts, run them to total destruction.Swap over? Do you mean flip over or swap to the other track?
Mine was a rental, so I assume all operators were novice. (I certainly am)
I call those contour tracks since they follow the contours of the groundHeres how a set of steel tracks on a 303.5 Cat look when they are on the road to total destruction. I weld the odd crack up in the links and keep em going. The machine only works around home now .View attachment 310681
