A local lumber yard's boom truck, poof! What a poorly written article, it reads like it was written by a third grader. https://www.eastidahonews.com/2017/11/boom-truck-causes-power-outage-small-fire-idaho-falls/
It's been known to happen...Yeah, he was driving with his outriggers on the ground, haha
I find that hard to believe. Even if he was driving with all his stick out, which might happen, surely the hook wouldn't be hanging so low? Plus, it's hard to be sure as I'm using my phone, but the boom looks like it's over the side.Yesterday while setting trusses for a local builder, he mentioned he'd heard that the operator had run out of reach, and lifted the out riggers just clear of the ground, left the stick out but as the pics show at a pretty steep angle, and was in the process of driving the rig a few feet, just far enough to reach the last few trusses, when he hit the lines. Amazing!
And it would still feel pretty hairy. I've moved a roughy with 24m boom over the front (80ft?) And that's pretty tough on the sphinter. It has chart for pick and carry with that much boom over the side at about 45°, but I was never game to try.I don't see that rig with the boom over the side (yes kiwi- he's over the side) and telescoped out that far, being able to drive anywhere with the outriggers up. You wouldn't have enough over the side stability to do that. You might be able to boom straight over the rear and lift up the jacks and move it, but not over the side.
Yikes, where your fingers crossed the first time you crossed your limits of approach, hoping they remembered to turn it off.View attachment 175614
Todays mission. These ones, obviously, are de-energised. The circuit on the other side of the pole, however, still has 110kV running through them. This is as close as I want to get!
If you look up the pole, you'll see earth drains running from each phase back to the pole. These are their working earths.... There are also earths one pylon away at either end of the work area, those earths are the first to go on once the switchyard has confirmed the circuit is de-energised, and the last to be taken off after works are completed.Yikes, where your fingers crossed the first time you crossed your limits of approach, hoping they remembered to turn it off.
