Snow plow update
phil314
Otsego, Mn
Instigator of Choas
I used to use a unimount plow on my 1845c to plow my driveway. For the most part it's worked fine. Then I swapped it over to my new S650. I had to make a couple changes to it to make it work and it got me through last winter, but it was obvious it needed some improvements. This presented me with a chance to go way overboard. Challenge accepted.
There were several things I wanted to fix about the plow
1. The unimount pivot point are notoriously weak point. I've already fixed mine twice (pics).
2. The angle speed was crazy fast and hard to control.
3. It tripped far to often when pushing into snow banks.
4. Hydraulic cylinder didn't like the psi of the new machine.
phil314
Otsego, Mn
Instigator of Choas
First issue was to build a new nose pivot for the frame. I vaguely copied the updated version of the western ultramount. Funny even western knew the unimounts were weak.
Start with some scrap steel and a very large bolt.
20190727_122747.jpg 20190807_204244.jpg 20190808_195800.jpg 20190808_200222.jpg
phil314
Otsego, Mn
Instigator of Choas
Cut the old nose off and weld the new pivot onto the old frame.
20190820_150716.jpg 20190820_154942.jpg 20190822_133631.jpg 20190822_133732.jpg
phil314
Otsego, Mn
Instigator of Choas
Next I needed to build an entirely new quadrant from scratch.
20190808_200106.jpg 20190821_135002.jpg 20190822_141241.jpg 20190822_141430.jpg
  • Like
Reactions: DB2
phil314
Otsego, Mn
Instigator of Choas
Then add some hydraulics. Cylinders are dual action and 2.5 times the volume to slow the turn. Mounting points here were critical to get at least 30 degrees of turn with 10 inches of travel.
IMG_20191009_113428.jpg20190922_185223.jpg 20190923_123147.jpg 20190923_174553.jpg
phil314
Otsego, Mn
Instigator of Choas
Then add some brackets for quad springs and dual shocks. And finally some paint.
20191009_132411.jpg 20191020_181714.jpg 20191020_181727.jpg 20191020_181751.jpg
phil314
Otsego, Mn
Instigator of Choas
I've been working on this part time for the last couple months.
This weekend I put it all together and tested it out.
20191103_103231.jpg 20191109_175551.jpg 20191109_175629.jpg 20191109_175644.jpg
