skytrak 5028 transmission
icestationzebra
I know its a Ford C6 but I can't tell you if you can remove it without the engine. I'm guessing it is just easier to pull everything since the transmission isn't divorced like on the larger models. The larger models are set up so that a set of forks can slide under the engine mounts to make it easy to slide out the engine out the back, but don't know if the 5028 has that feature? ISZ
