short
mrfixit77845
texas
i have a 650h dozer wont start has no power to fuel solenoid fuse in panel at altenator/start aid blows on contact looking for a wiring diagram can some one help?
mg2361
Pennsylvania
Equipment Mechanic
Does the unit crank/start?
Does your unit have an ECU? By serial number it should. Any codes?
I believe that fuel solenoid fuse is not used in your serial number. That one is or is not blowing? Just the Alt/Start Aid fuse blows?
mrfixit77845
texas
thanks everyone for your responses.. I tracked down the issue as a helper or someone swapped the wires on the alternator for meter ground all is well thanks so much guys
