Mark250
- Joined
- Aug 30, 2015
- Messages
- 1,243
- Location
- victoria,Australia
- Occupation
- heavy equipment technician
hi ,Fulatora in your machine list above you have given general machine types ,machine model designation would help to determine tooling more accurately eg the 966 can vary from mechanical fuel system to fully electronic this goes for the hydraulics and transmissions as well.
as for tooling, I would include a hydraulic hose press with an assortment of hoses and fittings to suit, I would also include a nitrogen freezing set up for installing bushes and bearings, you will also need nitrogen charging equipment for accumulators, add hydraulic test gauges and adapter fittings for orfc and jic as the majority of cat equipment will use these.
you will also need fuel pump timing gear for the machines with the cat engines eg 120m (timing pins, pump timing brackets etc)
don't forget suitable hard standing areas for jacking etc
the list can go on, just supply more machine details serial numbers and models
Mark
Mark
