Don Harward
OK, my 1150 loader won't lift a bucket of dirt. In fact it will barely lift the weight of the loader. Now this happened pretty much all at once. I was working a big pile of dirt that I had heaped up with the Kobelco pulling one load at a time and using it to track in the dam of a new pond. I pull into the pile low gear and raise and curl, just like a thousand other times, but this time, with a bull bucket, the thing won't lift anything!
Imagine that an old Case breaking down...That is sure unusual! (Not)
So I pull the side panel to get to the pressure control valve and the SCV's and hook up my trusty hydraulic gage.
Note: This is totally old school! The only computer this thing ever had was the old apple phone that was sitting on the tracks which I forgot to remove when I took off one day...another story
So I lift and roll back to stall and the gage only shows 600 psi! It is supposed to show around 2200 psi.
Anyone ever seen this or has all of these machines been relegated to museums? Personally I like keeping the old thing alive and working. Its a beast when it runs.
Thinking O-ring in the pressure control valve.
Could be the pump, but all at once??? Doesn't seem as likely to me
Ideas? Comments? Criticisms? Advice?
