Hoping someone has ran into this before. I had to climb up on the hood of the grader to be able to push down hard enough to get the rad. cap off to check the coolant. Put it back on but it wasn't aligned the same. Have the 1st stage loose but can't get it off. I tightened it up where it is but want to be able to get it off in the future. Is there a trick to removing them? It needed a really good push and was hard to turn even with the handle when I finally got it off.
