Sailorman
I almost have the head off my old dozer but although I took 3 bolts out of the water pump/gear case housing cannot get it loose. Reading the shop manual, I see I must remove the water pump. There must be some additional bolts behind the pump?
Can I get this out without removing the radiator?
And what are "fire rings"? Are these what seal the head to the sleeves? Why would the cylinder sleeve protrusion ever change?
thanks in advance from the neophyte.
