RC30 not charging
Chrismhartley
MA
New here so hope I'm not bringing up an old problem I looked but didn't see anything so here it is like before it started with the controls locking out while the machine was running which we determined was low voltage and was fixed with a new battery so after that was down I realized that the alt wasn't charging so went ahead and replaced that well even with a new battery and new alt still not getting 14 volts anywhere not at the battery or the back of the alt I did notice there an alt diode in the fuse box this is were my knowledge ends not sure if that could go bad or be in backwards
Thanks for reading
DIYDAVE
MD
No need to post duplicate threads, the ASV RC-30 thread should go here. I have one, never had any major problems with it. If you are not getting the voltage, I would start with the manual, I know you can get a manual downloadable, Google search perkins 403-D 15. I would have a starter/generator shop check the charging system, were I a novice. Long and short of it is, either diodes, wiring or alternator. I had an alternator on mine, that the brushes were gummed up with dirt so bad, that the springs wouldn't push them onto the armature...
DIYDAVE
MD
I just looked, manual only shows r&r, google 10SI alternator, for info on testing alt...
74inchShovel
Washington
When you turn the key is battery voltage applied to the field terminal of alt? Is battery voltage present at the larger wire? I have three of these in service and replace at least one a year. Bad design. At some point I will retrofit common auto alt.
Chrismhartley
MA
Ended up running a new wire from the fuse box to the alt and haven't had any issues since thanks for the help
