Farmer Brown
I am having issues with a Kubota KX121-3 S Series Mini-Ex. (2200 hours) the machine was parked for 3 weeks and not started but was running great when last shut down. The next time it was started it started perfect and idled fine while it was warming up. The as I started to drive \it started bogging down and sounded like the engine was about o die. I let off the forward controls and the engine smoothed back out and seemed okay. I checked the fuel gauge and it was at 3/4 tank. I was starting down a hill so thought it may have been about out of fuel which is what it sounded like. I managed to baby it down off the hill to a lower area to do some work and it seemed to get better as the machine continued to warm up. However when I when to use the bucket it would almost die again. It did this three or four more times and then it cleared up and ran perfect the rest of the time I used it that day Approximately 4 to 5 hours work time. The next day I went to use it again and this time it would not clear up and run no matter how long I let it warm up. I finally shut it down.
A couple days of sitting once again due to rain I purchased a new OEM fuel filter from Kubota. Also purchased diesel fuel additive that was supposed to remove any water, slime or algae from tank and also was supposed to clean injectors etc. ($20 + per bottle.) I added the prescribed amount of additive to the fuel tank. I then removed the sediment bowl and cleaned it out. There was no water in the bowl at all, but had a tiny amount of what looked like dirt possibly in bottom of it. I then removed the air filter and inspected the (outer air filter) It had some dust in it that I was able to tap the filter and it seemed to knock it out and I stopped when no more dust fell out then replaced it and reassembled the filter canister.
I then tried to start the machine and the sputtering and bogging down started immediately. I decided to let it run for a longer period of time to let the fuel additive and cleaner have time to work through the fuel system but it never cleared up. The machine with no load and at idle or with the throttle up to mid- way it makes no difference. It will run perfect then suddenly start to miss and then almost die and shake and sputter, puffs of black/white smoke then clear up run perfect then after few seconds or at times maybe even 2-3 minutes it will again go through the sputter event again. Doing this over and over no matter if engine has warmed or not. What else can I possibly check and also if it's an injector pump is there a way for me to check this to be sure without special tools etc. before purchasing one. Any help is appreciated as I get further behind by the day. Thanks in advance!
