ABruso
Hi all, I have a 2 acre compost site that is on a dirt surface. The surface holds up pretty well, its not clayey, but the ground can be moist under the piles and in the winter. I have a 99' Cat 928G with its original 2.75yd bucket. We are usually picking up and dumping material, so about the same amount of forward as reverse. Alot of tight turns too because my site is small.
My tires are Michelin, when I spoke with the Cat dealer's tech line they said to inflate front to 30 and rear to 25. The tread on the tires are probably 30% left. Because we do food scrap compost, the ground can sometimes have objects such as knives, forks, and wine bottles. I have 3 questions...
What would be good inflation numbers given my working surface and the potential for hazards?
What would be a safe way to inflate the tires given that there could be a slice or weak point that i don't see before inflating?
If I do find a slice, what kind of repair can be done to preserve the tire.
Thank you!
Thank you!
