TreeHogger
Greetings - when I was looking at my machine to purchase (out of state, and beastly cold), it had been sitting and obviously not very well cared for - and all the fluids were down...
The hex release that was supposed to be there to unlock the cap for hydraulic tank was apparently not 'in there' and the long and short of it was that I broke up the cap getting it off to add fluid.
My two-part question is: Should I replace it (dealer?), or is it fine that it doesn't hold the 5 PSI as long as it doesn't let rain water in??
And, what makes this pressure? Is it simply the returning hydraulic fluid, or is the some sort of pressure-making system (E.g. air, or supplemental hydraulic pressure routed to the tank)?
I would add that the machine will be used around the farm, and not fasted paced production work like pipe laying...It is a 1990 490D with 9000+ hours
Thanks,
Mark
Thanks,
Mark
