Pauly17
I'm having Hydrolic fluid coming out of my travel spool cap when I was testing travel Pilot pressure. When testing the left forward pilot pressure the pilot pressures fine but when I pullback on the control to go in reverse it will spray Hydrolic fluid out of the travel spool cap. Any ideas what could be causing this? Can I pull the travel spool out to inspect? I'm having issues with the travel only on the left side it seems. I checked all the pressures both high and pilot and this is the only thing that is happening that doesn't seem correct.
