If it's anything like an EX200 then it's pretty easy. You'll need to open the door behind the cab. Down on the bottom of the compartment will be two rectangular blocks with a bunch of hoses going in each, and a few wires too. The block closest to the compartment door is the one you want, or at least it was on my machine. I don't know now off hand which hose is which but you'll be able to trace it out to your spool valve fairly easily. Simply follow the lines from your boom and your stick to your main control valve, then see which pilot lines (the small ones coming from the cab) operate the stick and which operate the boom. There will be 2 for each circuit. Follow these lines back to the block you see in the picture. Now comes the important part. Mark all the hoses you're going to remove. That way you'll be able to switch 'em back if things go south. You'll want to disconnect them and switch them on the cab side of the block because it's got some sensors in there that I'm not quite sure what they do but if you switch the lines on the valve side of the block you'll have other issues. When you go to mark the lines, you may have gotten lucky and somebody had them marked before because I'm pretty sure that the backhoe style isn't standard on these machines. Again, ensure they're marked. On my machine they were, but I can't remember which colours were where. Swap the pilot lines that go to the top of your spool valve with each other, and then swap the lines that go to the bottom of the valve with each other. I believe, but again I can't be sure, that the top lines on the block swap with each other and the bottom ones swap with each other, but you'll have to make sure by tracing them back to the spool valve. Once you have it switched, jump in and give it a try. When I installed my JD/Cat switch that you see in the pictures, I had the stick lines on the JD setting backwards and the stick would retract when you moved the lever forward. A simple line switch fixed this. Hope this helps, and don't hesitate to ask if you need any more clarification. Hope the picture helps, it's the only one of that area I have...
