monster truck
Well, after some dealing a trading my grandpa ended up with this 1973 Pete 352 with a 260" wheelbase and air ride rearends and cab. When we got it a last weekend we knew that the motor ran and that was about it. It leaked air so bad that it wouldnt build over 20 pounds, the pump to raise the cab wouldnt work, it didnt have any tires and wheels and the fithwheel was missing. The guy said he couldnt figure out the pump for the cab and since he couldnt figure out the air problem without raising the cab he had just given up and let it sit. I screwed around with it a bit and found out that the pump was just out of fluid and the air leak was just a line under the dash, ten minutes and a few tires later we were cruisin down the road to test it out.
We were told that it had a small cam 350 in it but after we finally got it home and jacked the cab up we were pleasently suprised to find an NTA 420 hiding under there! Behind that is a 13 speed eaton tranny and 40K pound rear ends with only 350,000 original miles on the whole truck! Yesterday it got a fithwheel and some new tires and wheels put on and this morning grandpa took it instead of his regular truck, he said it ran perfect all day other than the ac not working.
