Old IH 175 B Parts and Information Search
Will3170
International Harvester 175 Series-B, TD-175B (power shift), Serial NO. L 175 BP 12151. Emblem from engine block reads; "International-Hough
Manufactured Assemblies
749207C91
S11672"​
Trying to bring this old machine back to usable shape. It did run and operate a few years ago.
1) I am in search of a hydraulic oil cooler for this old machine. A few years ago my dad pulled the radiator off the front of the machine to see if it could be repaired, as it leaked, somewhat. He had the oil cooler laying on the front of the machine, and then the oil cooler just vanished into thin air while he was away form the house... Also, could potentially need a replacement radiator, and, dad did mention something about it may needing a water pump as well. Any information on where parts like this might be found, part numbers, or interchangeable options would be greatly appreciated.
2) It would also be helpful to have additional information for this particular loader. Information including, but not limited to;
  • what engine it has,
  • parts list,
  • model year,
  • other machines that ran this engine that parts would interchange from (agricultural IH tractors and whatnot),
  • and any helpful hints of maintaining and operating this old loader.
Thank you so much for taking the time to read my post, your knowledge and time will be greatly appreciated.
thepumpguysc
Its got a RoosaMaster inj. pump on it so.. I can help w/ the motor parts of it..
Give me the top line/mdl # of the injection pump & I'll look it up..
Will3170
Thanks for your reply. I appreciate your time. I think the injection pump, at last operation, was functioning as it should. The part I am looking for at this time is an oil cooler, and potentially, a radiator and water pump, but am going to assess those parts after I get it running. Below is the emblem from the injector pump, I think. IMG_2717.JPG
thepumpguysc
The engine is a DT407.. & it went into a TD15B & a 175L
I sure hope that helps w/ your parts search..
Good luck & keep in mind if u need any fuel system work done..
Will3170
Thanks for the information! I will definitely keep you in mind should I need any fuel system work done!
wrwtexan
The engine is the DT407, same as D361 and D407 used in 806 and 856 IH farm tractors. All States Ag parts will have the water pump. I have a TD20B which the oil cooler was ruined in and I mounted an used aluminum trans cooler with new hoses on it in front of the engine radiator. Ray's Used Equipment in Nocona Tx might have some parts for it.
Will3170
Thanks for the useful information. I appreciate it for sure.
Will3170
Just FYI, All States Ag Parts indicated, through a chat conversation, that they do not have the water pump, radiator, or oil cooler for the 175B.
Thanks again.
Labparamour
http://www.redpowermagazine
Red power is all things International and have several forums- including construction equipment.
I think this link takes you to the “magazine” page but, you can click on “forums.”
They helped my son with his TD-7.
Darryl
