Not Starting
Towbarman
North Little Rock, Arkanssas
Towbarman here. I have a 2010 M1120A4 (PLS), Palletize Load System. It had issues with 2 injectors. Put the new ones in and still had the issue of engine light on. I checked the wiring going to the injectors and no power to them. Changed out all wiring harness's, Speed sensor and crank sensor. The last 2 had to be changed out due to a new mechanic breaking them. Everything is hooked up. Went to start it, would turn over but no start. Put our Snap-On reader on it and it showed Low coolant, which it isn't low. Quick stop Occurance. 84 FMI 4. 111FMI 11 Flash Code 62. Any help will be appreciated.
