Can’t get our 2006 Ford LRG425 (SN# 06VG56426) engine that is part of an Eaton 21kW backup generator system. Here are the particulars:
This system resides in cold weather (Illinois) and does have a heater. Engine temperature at the top of the block is 90-95 degrees.
Any help in further troubleshooting would be appreciated.
Thanks
- Engine configured for LP gas. Verified shut-off valve opens properly and I see ½ PSI before entering the zero pressure LC-50 throttle body.
- Verified that thecarburator butterfly moves freely and operates correctly when the engine is cranking
- Did compression testing on cylinders – all around 130 PSI
- I see spark when I remove spark plug wire and test for spark
Thanks
