NCman
No, I just put everything back as it was. Now it cranks immediately so no more breaking out the jumper cables
Did a bunch of work with it yesterday until a hose at the low point of the boom blew out. I took it to oreillys and they did not have the right fitting. Then called two other hydraulic hose makers and they did not have the fitting either. The fitting was a straight male end with a flat face and a recessed o-ring. What's so rare about that fitting? Finally drove 40 minutes to a hyd. shp that had the fitting and got the hose made and then installed last night.
Side note; When I am working with the hoe I hear a whining sound only when extending/retracting the dipper or stick. I have noticed that one of the backhoe control valves is wet. Seems to whine less or more depending on what rpm I am working with. Also the right stabilizer is not as strong as the left. Is changing o-rings under that control valve a simple job? Looks like 2 allen screws will give access to the problem???
