Like some have already interjected, w/o a set of plans and specs, you really don't know the intent of this project; and I personally have not been to this exact location but can say, from experience, what I think is happening.
Most levee systems exist because surrounding topography is low; therefore the need for a levee. If the adjacent topo would be higher, no levee need exist.
Most levee systems incorporate seepage berms on either side, and sometimes both protected and unprotected side of the levee. These "berms" are built only to serve as weight. This weight disallows the development of what hydraulic engineers describe as a "flow net"...... actually it is the movement of water, not unlike a river, that flows under the levee reach. Levees typically fail from the bottom, not the top, contrary to popular belief. This is why the sand fill is acceptable as fill... the Corps is only trying to add WEIGHT. This WEIGHT makes the dreaded flow net very difficult to perpetuate.
The filter cloth (geotextile fabric) is placed to help bridge over the underlying unsuitable material, mostly to facilitate fill placement.
Good levee construction need not consist of 100% impermeable material. The Corps will sometimes zone certain borrow material for placement. Typically, more permeable materials (sands and silts) will be placed on the Landside, aka the Protected Side, and the more impermeable materials be zoned for use on the Riverside, aka Unprotected Side. Most of the time, impermeable materials are preferred, especially to encapsulate the earthen structure............. but the sad reality is, that it's not economically feasible to use clay materials everywhere. Clay is a commodity in New Orleans; and when I say commodity, I mean it. Good, high plasticity indexed clays are worth sometimes as much as $30/ CY, delivered, in place. The cost breakdown is typically like this: $10/ Cy just to purchase the material, pure slop, by the way. then $12-$15/ Cy just for transportation, then about $10/ Cy to process (dry the slop out) and install in lifts, compact, and dress. All said, it's cost is about $30/ Cy!!!!!.............
By comparison, the taxpayer can save $5/ Cy by using sands in lieu of clays. And if the purpose is to simply add weight, then sand is a good alternative to clays. BTW: Sand can be bought for $5/ Cy.
Hope this helps some of you. I know that all that money being spent here in South La. is a sore spot for the taxpayers... but there are more interests than meet the eye.
