I have a Pel Job EB 12.4 with the mitsu L3E 0,95 liter 3-syl engine. The machine have done more than 5000 hrs, and have not seen lots of maintenance.
Overhauling this engines cost a lot because of expencive parts.
I have got an offer for a L3A engine. This one is 0,7 liters and does have a little less power at the same revs as my L3E. The L3A is good for 3200 rpms, and the original L3E 2200 rpm, so the L3A is rated with higher HP.
The higher revs have no interrest in a mini digger. Power at 1500-2000 is probably what I need the most.
Will the lower torque in the L3A be noticeable?
Is the L3A a good replacement for the L3E?
Known issues with my engine :
Noisy
Smokes a lot
1 glow plug is 24V
Hard to start under +10C (the glow plug have some influence, but I suspect low compression)
Impossible to start below 0C (freezing)
Uses 1 liter oil for every 40 liters diesel.
Injectors probably not working well.
Suspect worn head gasket
Low power.
Noisy
Smokes a lot
1 glow plug is 24V
Low power.
