any one have any tips on installing pvpk1 busing kit on case 580b ; Ie when you weld on the large bosses that hold the outer bushings, do you tack them in place whith the pin lined up, then remove the bushing before final welding so the bushing does not get to hot, how many passes of weld, what rod, large taper on boss inside for weld room or facing out. Thanks. did search found no info.
