willie59
I'm replacing the seals on the tilt spool of a 763 this weekend.
From the posts I'm guessing if I'm careful, I can take out the 2 allen's holding the detent cap on the lift spool, and pushing the spool from the link end - push it out of the valve body and just leave the end cap/detents in place?
I left the valve attached, and thus far pulled out the tilt spool (it was leaking a stream out the little hole in the end cap)
That's the way I do it. I can't remember for sure on the 763, but you may have the control valve locks like on the 773 and other models. If you do, they hold the spools in the locked position when machine isn't running and you can't pull the spool out. What I do is take the linkages loose connecting to the spools, remove the rubber dust boots, have the seat bar down, turn on iginiton, then press the drive enable button on the control panel. This will release the spool locks and you can slide them off the spools at the front of the control valve. The float detent mechanism is only on the boom lift spool, the end cap is longer and has a snap ring on the end of it. You don't have to remove the snap ring uness you need to make a repair of the float detent. Otherwise, once you've removed the spool locks from the front of the valves, you just remove the two allen head screws that secure the end cap to the valve body and slide the entire spool out of the rear of the valve body. It will usually bring the seal along with it. Remove old seal and slide matching new seal onto spool, then insert spool back into valve. Just be careful sliding new seal on spool, the machining is sharp and can damage the seal if you get rough with it.
