Tippiness?
It's been awhile since I was able to spend much time with the ol' Rattletrap.... scratched my cornea, deeply, right in the center which meant I spent most of the summer seeing double! That's fixed, so back to some time with the old girl....
Turns out the generator had been upgraded to an alternator sometime in the past and it's not working. Time to pull it off and check the diodes.... I did loosen the tracks so they have the appropriate sag and aren't banjo tight! Checked all the fluids (good to go), topped off the hydraulic tank (regular task owing to the leaking gland seals (to be fixed) and managed to get about an hour of seat time in cleaning up an old clearing project--which leads to a question.
How tippy (side-to-side) is a 955? I always have this fear of running a track off into an unseen root hole. And sometimes I have to deal with relatively steep hills. This being my third track loader, I know they aren't nearly as stable as a dozer, but my JD 350 is a billy goat and will let you know when you're pushing it. But I can work the 955 so much faster--and things can happen in an instant. Any suggestions from more experienced operators? If you're clearing brush in an unfamiliar area, how do you deal with unknown and unseen washouts? Just how stable, or unstable, is a 955 anyway? Assume multipurpose bucket down close to the ground. And it has all the counterweights in the back, around the hitch, too.
Had the camera with me today, but forgot to take photos! Next time.....
