Personaly I prefer the tripple shank for about the same reasons as DPete mentioned. If I am in rock that needs a single shank, I usually have that dozer working out ahead of me. I know that is not an option for everybody but I am quite happy with that arrangment.
I have run 8, 9, 10 and 11's with tripple shanks, that had adjustable pitch. It was also possible to adjust the legnth of the shanks but you had to manualy knock the pins out. I did run a D8R once that had a single shank ripper that was converted to tripple shank and that still had the hydraulic pin puller on the center shank, I found this usefull on occasions, when I hit a little tuough stuff I'd lower the center shank and loosen things up with that. Also the three shank set up is way faster in easier going, the single set up has to do three passes to cover the same area.
If in an area that has a lot of boulders of a certain size I have found that the single set up can shift them from side to side, the tripple brings them to the surface usually.
Make mine a tripple!
