This is everything I have...
https://www.dropbox.com/sh/mzkhy958xi4isje/AAD-Zia6ZoL4VXffkdPXCeyXa?dl=0
an update
I came to the conclusion my unit was no good as it was so I dug in. One thing learned, the control panel must have power/led/display on for the unit to have any function. On the schematic I have the bypass button has two wires one to the small remote unit and one to the main computer unit. While tracing out, found only one wire going to small remote. On separating the two boards. They were held together with a soldered in pin header. The first pin I cut with dikes pushed the printed circuit land from the board. This was no good. Found a fine tooth saw in a hobby kit and sawed the rest of the pins into with no issue. Moisture had gotten in the unit and the backs of the boards had a lot of crud on them. Cleaned this up. Had coil leads broken loose from board. re soldered. Went over the board with rtv anchoring capacitors and coils in place. Decided to power up and trouble shoot. Mounted boards on plastic where I could get to the back and front. Soldered leads in to take place of header.
Powered up. Display and leds lit up. HEY THIS THING MIGHT WORK! It did. after abut two months Success. The folks from this forum sent prints and info to make this possible. Thanks
Have you tried the "Fordzilla fix" yet? If so how about an update.I've recently acquired an MM40 in Australia with the same issues Fordzilla is talking about. The machine has been to heaps of mechanics with no good results. I'm anxious to try this out on mine. Keep the thread alive! Cheers!
here you goIn dire need of schematic for Mitsubishi 55 SR. Any help will be appreciated !
Can you send the manual for Mitsubishi mm40-55sr please. Here is my mail RomanO_Best@mail.ruIn the spirit of giving out information on these Mitsubishi MM series excavators (MM50SR, MM40SR, MM30SR) I’ve started to put all my information on my website www.woodandtrees.co.uk which you are welcome to access.
It includes the MM50 electric diagrams, fault finding and error codes that “tool_king” and others have posted, Parts Manual and SL series engine operation, maintenance and service manuals. There is also some other stuff on my own machine MM30SR and information from “IronDino333” on ram seals.
If anyone has more information (or write ups on what they have done on their MM machines) and are willing to share, just contact me via messages and I’ll add it to the site.
Hopefully this is useful.
Graham
To remove the the rotary position sensors from system you need to take 2 2K ohm resistors and make a voltage divider. The voltage value will be about 2.5 volts. Solder one end of one resistor to the 5 volt line, next connect both resistor to the signal line and last connect the other end of the second resistor to the ground line. I'm still looking for the schematics for the MM40SR myself. I hope this helps someone!Ok, as I talk to myself here in this thread, maybe it will help someone else down the road. Installed 2Kohm resistors into each of the 3 sensor wiring connectors and disconnected sensor. Unfortunately no progress as it just changed the error code from an E-22 to an E-21.
I get E-22 with 1 or more sensors disconnected (without resistors), and then get E-22 with sensors connected. but only E-21 with resistors only. So, no progress, unless I am installing the wrong resistors.
Great to hear you got your machine working again. It's good to know there are options to get the computer replaced, as I always wonder what to do if it breaks. Do you have any pictures of the new setup and advise about the installation?I got sick of trying to fix one after another problems with my 98 MM40SR computer positioning sensors and monitor I spent $375 to be told my monitor was fried and couldn’t be fixed and no replacement to be found by a high priced reputable repair company I got ahold of Tony-IMDynamics he fixed me up with a MM-R16–3 it bypasses all the original stuff all it uses is your original joysticks and the valve body I just put on in my machine today I am back in business no thanks to Caterpillar I live in the United States and they don’t recognize these machines
Hello could you possibly provide this documentation again please? My dad's machine is experiencing the same problems. It's a mm55sr.. as wellThis is everything I have...
Were you able to obtain any info or documentation on the mm55sr?? I have one as well. That needs this help.In dire need of schematic for Mitsubishi 55 SR. Any help will be appreciated !
Have at look at https://www.woodandtrees.co.uk/ This is where I've put all my information on these machines.Were you able to obtain any info or documentation on the mm55sr?? I have one as well. That needs this help.
Thanks in advance.
