All our local dump truck drivers won't turn the key on 50,000lbs gross, unless they've got 1800-2000 ft.lbs of torque and minimum 550 hp.
At the time in early 70's the engine was 1693TA with the rack screw pulled, if a engine back then
produced 13 to 1450 it was a big deal. But it's what happens when society gets a little spoiled with
todays power. Most trucks needed a main and auxiliary gear box with 7.50 ratio drives and lower.
If all the electronic crap died today and all there was to drive was yesteryear equipment I guess
many would either learn how or starve.
This moved a 14A D8 used for cutting logging roads-1956 B71 with a NH220, three stick------------
high/low range with a 5 speed main and 3 speed Auxiliary and some real low ass gears 9. IIRC.
No P/S, No A/C, and not much heat in winter with air wipers, and stationary drivers seat. Pulled
a Peerless fixed neck.
