CaseFan13
Did you part ways with your Case?
I'm sitting in it.Did you part ways with your Case?
Thanks, Simon. I'm strictly a Spectra guy. I've tried others, just don't care for any of them. It's probably a Ford/Chevy/Dodge thing, and that's fine. I use the 722 because I need the range. Sometimes I have to survey several miles of ditch, and it's a royal pain leapfrogging the laser. If distances aren't a big concern, the 622 would probably be fine. I purchased an LR50 a few years ago when I had the need for two receivers. Either receiver works good, the 50 has the tilt lights so when the excavator isn't level you can use those to judge with.I have just read 10 pages of your posts, and you have a sure knack for doing everything right. What Laser would you recommend that could do the work you do but without all the bells and whistles. You previously stated that you use a Spectra Precision GL722 And a LR60 Receiver if I have it right. Some models have changed now, and I understand that some work faster than others. C-mark uses a GL622 he stated in one of his posts. Wondering what would work well for a guy starting out. Any info appreciated. Was a very interesting read. Keep up the info line. You have helped a lot more people than you think.
Simon C
The road was down to one lane, and it was on a hill so it was dangerous for traffic. I pushed both sides back. Hopefully they will have enough room for the rest of the winter. If we get a bunch more big blows, I may have to shove it back again.A big blower would work but I think it might be a little slower depending. Did the job above just require getting a lane open so a grader could finish or clearing the whole road and pushing the snow back as well?
So do you end up loading it up afterward and putting it in your shop to thaw it out each time? Or just keep it cold?
It depends. Last week Friday it was blowing like crazy, almost to the point I couldn't see what I was doing. I ended up taking it back to the shop because about mid-afternoon the thermostat decided to stick open. I have a little propane generator that I run on a 100 lb cylinder if it's getting colder than 15°F. It will run the generator for about 50 hours.
https://orchardgenerator.com/products/Champion-200960-%2d-1700-Watt-Dual-Fuel-Inverter-Generator-w{47}-Parallel-Capability-(CARB).html
It was cheap, and easy to drag around.
I guess my response was kind of confusing. C/O asked if I take the dozer home every night. Most nights I keep it plugged in off the generator.Do you run a heater off the generator? I guess I don't see how you're using this to help in the cold.
I'm not entirely sure yet, initial thoughts are at least 25% faster. Meaning, what would have taken 10 hours with the Case I do in 7.5. The best thing is the diff steer. That little Case was a pain in the azz to make small adjustments. The Cat I just go wherever I want. And the HVAC is so much better for fogging.How much more does it push than your Case dozer? I seem to recall the county had an issue with the grab handles beside the grill. I think it had to do with branches getting caught it them and potentially damaging the grill and/or the rad.
