gdog146631
shutting down (LS140)
I have a NH LS140 skid steer that keeps doing an automatic shutdown. It will start beeping, the battery light will flash, then it shuts the motor down. No error codes show on the LCD. Sometimes it will run for hours without shutting down..., sometimes it will only run for a few seconds. Once it starts doing the auto shutdown, it seems to happen frequently, but with no pattern: run for 5 minutes, then only run for 5 seconds, then run for 2 minutes, then 10, ect....
The battery voltage is at 14.5 volts when running and the LCD readout on the skid loader agrees.
I had a skid loader that did this in the past. I think it had a bad engine oil pressure sender. When it was acting up, the idiot light for engine oil pressure would light up and then it would shut down. That is not the case here.
