funwithfuel
Where you at in this? I mean. I'm talking generalities here, but have no real knowledge on what he's up against. What's yer thoughts?Did I miss something, or did the OP not mention which 310 model he has?
Like Funwithfuel said--the outer seal on a piston type stat. It's common for those to beMaybe there is supposed to be the inner seal like you say and it wasn't there?
Yeah the outer seal was on it and I was careful when putting it in and old one looked fine too. Looking at diagrams here and noticed there's a coolant bypass valve on top of the radiator. Any idea what that does exactly and can it cause my issue? Just a thought there's nothing else to the entire system it looks like except that bypass valve and thermostatLike Funwithfuel said--the outer seal on a piston type stat. It's common for those to be
missed, just a little tear can flow allot of coolant.
I would guess as exactly as it's noted-bypass. What hoses feed it? or does even have hosesAny idea what that does exactly and can it cause my issue?
There's a seal in the bore that the tube body must fit tightly into it. If it "fell" right in, it's no good. You should feel resistance when pushing it in.It's vertical and looks more like the one on the right. How can I check if the cylinder head is airlock? Heater hoses appear to have good flow. I was reading if that thermal bypass valve is stuck open it can cause low Temps apparently
Couldn't you just block it off to test? Take one hose off, plug it, put another short chunk with a plug on that fitting and see??I got the gun coming today so tomorrow or Monday whenever I'm back I'll take some shots and see what's going on but i think it's the bypass valve. John deere claims a stuck open bypass valve can cause low temperatures but I'll take shots first before I do that it's over 300 bucks for a little valve
