Kubota SVL90 14pin connector
Hysert
Ontario
Hey guys new to this site... I want to run a soil conditioner /harley rake on my SVL? However I want the buy the bobcat brand soil conditioner, (heard better things about them) the BC one has a 7 pin to run the angle cylinder valve! Is there an adaptor for 7 to 14 pin? Thanks
crewchief888
NWI
it might be best if you contact your bobcat dealer and ask them to check out "attachments plus" they should be able to tell you exactly what you will need
:eek:
bobatack
Ontario, Canada
Not sure if you will findan adaptor like that, but i know most of the later model bobcat attachments that require the 7 pin harness have an electronic controller on board the attachment.
so that being said the machine and attachment speak thru the 7 pin harness (not sure if Kubota can speak same language thru adaptor)
Hysert
Ontario
Got some more clarification yesterday!! The hydraulic angle unit also has the hydraulic front axle lift! The valve body had 5 coils therefore would require a 6 switch setup.. I spoke to skidsteer genuis and they have a "super controller" that will run it however the kit involves clamping 2 small joysticks to my machine joysticks to operate the functions! Don't really like that to much. At around $1500 I'm not gonna go that route now!! I will get the manual unit and for the few times a day I may need to angle I will get out and swivel by hand... thanks for your reply!!!!
