mikebramel
I can't get to the thread but if you purchase that solenoid valve
http://www.surpluscenter.com/item.asp?item=9-7989&catname=hydraulic
http://www.surpluscenter.com/item.asp?item=9-4019-50-H&catname=hydraulic
There is your cross over which I would set it 2000
The valve is only rated for 5GPM so if you have a 4" bore cylinder and a 24" stroke it will take about 10 seconds
You can keep your auxiliary valve that you have connected and tee this one off of one of the inputs to your valve bank off of one of the variable displacement pumps
