oldhousehugger
Banjo bolt with strainer question.
John C you wrote in 07 that the Komatsu engine on an excavator had a strainer in the "lower" inlet side of the lift pump. I have been having the same fuel starving, stalling issues with my little D20. When I took the big hex cap on the side of the lift pump off I got a glob of grit out along with the spring. Also the handpump seemed not to be getting very much supply even though the fuel was free flowing from the main fuel line.
If there is a strainer which clogs regularly, has anyone done one better and put in an inline sediment bowl and got rid of there strainer?
The problem there is space and accessability.
Is there a rebuild kit available for the lift pump and hand primer?
Old
Hi Grubber, it's great to hear you got it going.
I just need to remind you that the fuel filters are down stream of the strainer I spoke of in the earlier post. If the fuel filters are plugged then so is that strainer.
You will probably see it on a long travel up a hill.
Good Luck!
Old
