Dear professional members,
I recently had an issue relating to engine overheating,the engine had major mechanical component inspection on board but did not find any suspicious error and the hydraulic main pump was also adjusted to lower the engine load,which regarded as the main cause of the overheating but those did not give much difference,as the work operation was urgent,one spare engine was sent to replace it,improvement was,but not much,the previous installed engine was disassembled at the cylinder head to inspect the combustion chamber,all the 6 pistons surface found with white pattern so was the cylinder head part for each piston,does the white pattern mean something,
I hereby attached some photos
