PbBelly
My cousin is running a Komatsu PC138 USLC-2EO excavator ser# 2078 Product ID # KMTPCO44T044T01002078. He bought it 10+ years ago with 1,700 hours on it. From day one it has had a problem not steering when tramming once the machine is thoroughly warmed up. It works fine for the first couple of hours on a warm day and may not misbehave at all on a winter day. It trams fine, although it does seem slower on an incline once warm, but the only way he can turn the machine is to help things along with the boom. Sometimes he is able to steer it somewhat when tramming downhill. Apparently there is a separate pump for each side's drive motor, but both sides misbehave equally. Over the years he has spent over $9,000 with various Komatsu service departments trying to get to the bottom of this [pump rebuild, hyd. cooler repairs/mods etc.], and nothing has been successful. He thought the most recent visit had cured the problem. A Komatsu tech adjusted some of the pressure settings that were "low", and it seemed to have cured the problem for a few hours, but now it is right back to behaving as usual. Fortunately, this machine is typically used intermittently enough (load a truck and cool off while the truck was gone unloading) that it isn't an issue, so he's has lived with it. (it is up to 5,600 hours now). But there is some more constant work coming up in the future and he would like to get to the bottom of the problem. Several of the techs that have worked on it say they've never seen another one like this, but they also admit that they typically work on much larger excavators. The last conversation he had with the most recent Komatsu dealer he's been talking to ended with the suggestion that he try replacing the hydraulic oil with 30W motor oil. He doesn't like that idea.
Supposedly this machine was imported from the UK. Were their spec models different from those destined for the US?
Has anyone had similar issues with one of these?
