If you have the passcode, there should be a combination of key to disable the code.
Be carefull not make a mistake during the operation, if so you have to change the monitor.
The dealer should give you the procedure. I can give you the dash 8 procedure but I am not sure if it is the same, it is your responsibility. PM your email
