tool_king
BLSROCKS
Can you please call me at 1-201-832-1606 .Would like to talk to you.Thanks ED
i worked for Komatsu for almost 15 years there is no software needed to run diagnostics. It is all on board in
monitior's....only Instite for Cummins service and trouble shooting.....is needed for some komatsu's...
then it is hooked up at ecm in engine area...
Hi I have a pc200-8, I saw my Komatsu mechanic punch in a sequence on the keypad to prong up a diagnostics screen... Does anyone know what the sequence is?? Thanks.
was not able to find code E303 listed in PC300-6 service manual I looked at. E306 is abnormality in potentiometer feedback system. E308 abnormality in fuel control dial input value
I was a field service man with komatsu for many years up till last year, from my knowledge Komatsu use diagnostic ports on only large equipment for factory down load and some of the larger cummins engines, all equipment diagnosis e.g cyl cut, sensor outputs and calibrations is done through the various monitor panels. If you need to access any monitor for excavator, dozer or loaders regardless of series I can give you the codes
