tomfromhull
Looking to sell a bucket piston off of a sk400
Thanks! There is no solinoid on the pump, but there is a 4th one that I think is for the safety lever?Hi zipper. The bad wires and soleniods are where your going to start. Can you tell what wires went to witch soliniod? Can the wire harness be repaird? Is there a soleniod on the pump assembly itself? This is a older machine and I don't know off the top of my head wich coil does what but the one on the pumps is the most important one. This is the one that the cpu uses to controll pump flows. If it is not working the switch that baz is talking about wont work, I will look to see if our shop has a elec sch for this machine.
The safety lever should have a micro switch that disengages the levers from working when the safety lever is up.
