crane operator
They were looking for a 150 ton I think?
If it were my National 1100 series I would put a rubber contact wheel against the drum edge, and a drive band off that to a shaft under the boom where I could see it from both stations. KISS.New greer rotation indicator are $2,300 last I priced one. They are still the best solution.
All my pilot hydraulic rigs use a small "thumper" in the joystick, that pips up and down when the winch is turning. They tend to be not very durable.
I've run a crane that had a drive wheel on the drum running a cable, like a old mechanical tach cable drive, to a wheel in the cab. I can't remember what it was on.If it were my National 1100 series I would put a rubber contact wheel against the drum edge, and a drive band off that to a shaft under the boom where I could see it from both stations. KISS.
Sorry, I don't think I was clear- both my 500e's are pilot hydraulics. The only thing I have that is electric over hydraulic is our liebherr.Do the 500e have electronic over hydraulic controls?
That's fascinating to know. I've run the one the local college has, but really didn't look it over. I didn't know that grove tried electric on the 540's. Better hope the electric holds up, because they didn't build a lot of those, so I don't know what availability is on parts. Did you get the 115' main or the 90" main boom?Took a look under the arm rest and found nothing but wires
From what I hear, the newer ECOS controlled locking booms are problematic. Grove used to be the gold standard of hydro's.So what your saying is Grove mechanics arent like your typical Maytag repairman
Boy, some days the truth does hurt.
That is a great picture. My wife is a sunshiny day kind of person. I like a little clouds and cooler.So what your saying is Grove mechanics arent like your typical Maytag repairman ? Stuff is way too complicated now. Lifted unknown tons, driven 100s of piles ,clammed thousands of yards with this old girl. Shes still going ,never had a mechanic called out on a job ,just fixed the odd airline or hyd line on the carrierView attachment 312505 myself. I know im a dinosaur.
