Yeah, I finally got that pin out of the front tilt cylinder. It was pretty tight and it had worn a little "offset" in the center portion of the pin, which may have been hanging up as we were trying to pound it out with a huge sledge hammer. Now what I have looks like this (see photo). I tried to loosen that little set screw with a hand held Allen wrench. It wouldn't budge and I was afraid I would strip it. I will hunt for my 3/8 inch drive allen wrenches and see if I can loosen it.
I looked at the link that Speedpup gave for the chain wrenches. The largest capacity chain wrench listed is for 6 inch pipe and I believe that that particular cylinder exceeds six inches in diameter. I will have to add links to the chain? Where do you get the extra links? I'll have to measure the diameter of the cylinder this coming saturday to see how big of a chain wrench I need. Thanks for the link!
I'm planning on servicing all of the hubs and planetaries and brakes. This will cost a small fortune, I know, but at least I will know what I have when I'm done! I keep telling myself that this is all "for fun"!
I'm doing some research on how to best approach buying parts for the hubs and axles. The axle was made by Spicer, so an aftermarket supplier would be preferred over buying them directly from Lull? Or perhaps even buying them directly from Spicer? Is anyone aware of any axle shops that sell Spicer parts for off road axles online? Any other source appears preferable over Lull due to inflated pricing - is this rationale correct or are all the suppliers expensive when it comes to off road heavy duty axles?
Right now I have my machine with one tire off and sitting on wood blocks so I'm not able to check the fluid condition in the other planetaries. This brings up the subject of lubrication of the wheel bearings. I checked my lube chart and it does not mention the wheel bearings. Is it possible that the oil for the planetaries (the gear lubricant plus friction modifier) ALSO lubricates the wheel bearings?
I am uncertain as to who was responsible for allowing this machine to get into its current condition. The previous owner told me that they only owned it for three years. During that three year period, they must have performed zero maintenance, because the air filter was clogged with caked up dirt/dust, the hydraulic fluid was clogged, the hydraulic fluid contaminated with water, three (3) of the five (5) main hydraulic cylinders with moderate to severe hydraulic fluid leaks, transmission fluid critically low, popped out freeze plug and the condition of this hub as we are discussing. No wonder I got it for a good price!
Any literature on the Spicer PS-1350 axles greatly appreciated! Still looking for a scanned parts manual for the 644! I have the service manual for the 644 844 and 1044 on pdf and I can email it you!
