Jerbearbroth
I have a 1988 John Deere 644E wheel loader that has developed a transmission problem. When the machine is shifted from either forward to reverse or vice versa, it takes up to 3 seconds for the transmission to engage. Also, when it is traveling, and is shifted from 1st to 2nd, it takes up to 7 seconds to change gears. This problem came on very quickly (within about 50 hours). I suspected a modulator valve or something, but the dealer is saying that the transmission needs to be replaced. They say the clutches are bad, but when the machine is working, there is no slippage or performance problems other than slow shifting. I am just wondering if anyone has had a similar issue. I find it hard to believe that the clutches went bad within a period of about 50 machine hours.
Thanks for your advise!
