John Deere 50D mini ex injector install
mike holcomb
ct
i have a jd 50D #1FF050DXJA0275408 has a yanmar engine #4TNV88-BPHB , i went to put new JD SEB injectors in with new washer and tip isolator, the new injector slips in with ease. Is that how they go in? for some reason i feel there should be some resistance going in? old ones came out really hard. any advise is appreciated. Thanks
mg2361
Pennsylvania
Equipment Mechanic
Can't say I will have an answer for you since it has been years since I installed injectors in a "D". They shouldn't be hard to install. Yes, the hold down bolts are what keeps them in place, not the tightness in the bore.
Were the original injectors SEB?
Can you post a picture of the new and old injectors side by side?
thepumpguysc
Sunny South Carolina
Master Inj.Pump rebuilder
I’m not familiar with the engine but might know the actual injectors.. I would think that there’s some sort of “dust seal”
on them.. maybe an oring.??
If there is none, u better find the correct torque for the hold down..
Good luck
mike holcomb
ct
I was just surprised how easy they set in after how hard they came out. Put them in, seems hold downs crush the washer or push into place as I tq down the hold down. Yes they were SEB injectors that came out. JD # MIA883396
