Thanks for the reply
I don't think anything was left in the line, but figured it would be easy to check that filter so I pulled it. I checked the return filter and found nothing there. I even took out the filter and tried it, but the machine worked the same.
As I mentioned earlier, when you try to raise the boom or push the arm out, it creates pulsing vibrations. When you push the arm and curl the bucket some, it moves a little better (still pulsing some, but not as much) (and slowly). Without curling the bucket, it will not really move at all. The swing will swing slowly without pulsing. Auxiliary hydraulic thumb works slowly without pulsing.
