crpohio
I recently purchased a straight 410 backhoe. Reverse was weak. Split the machine and found the reverse brake housing had broken. Also found the clutch input shaft was worn badly.
I'm going to replace the wet clutches and ALL seals and orings while its apart. New dry clutch, throw out bearing and pilot bearing.
Has anyone reassembled a 410 reverser? And tricks I should know about? Is there anything else i should service while I'm doing this?
