digger242j
This is a machine that I don't own, but I do operate it often.
It has a problem in that the cab becomes uncomfortably hot. The valves to the heater core are turned off in the summer, so that shouldn't be the source of the problem. It gets hot enough that the other day a wrench left on the floor just inside the door became too hot to hold bare-handed, at least for more than a second or two. This isn't a recent development. This machine has always been this way, at least as long as I've known it.
Other than the problem with the cab getting hot, it seems to run perfectly normally. No engine overheating or anything. No apparent flow of hot air from the engine compartment into the cab either, but the metal gets hot.
Which way is the fan supposed to blow? I can see that if it's supposed to blow outward through the rad and oil cooler, you'd get a lot of warm air blowing out the side. The fan sucks inward though, all that warm air ends up inside the body (passing over the muffler too), and I imagine that could be the culprit, but I looked at the fan this morning and it doesn't look like there's a way it could be mounted backward. Could there be a shroud or shield or something missing back there that's supposed to direct the airflow so that it doesn't heat the cab up?
Anybody seen one with a similar issue?
