mg2361
Wow, you must carpal tunnel syndrome after typing all that out.
With the fuse removed, plug an ohmeter on the load side terminal of the fuse holder and check for continuity to ground. Then inspect the harness thoroughly for chafing through clamps or where harness go around bends. If nothing evident, then start unplugging connectors to maybe isolate a harness. Since it appears the only 2 items on that fuse are the ECU and the EGR valve, maybe start by unplugging them to see if the short to ground goes away.
For many of those codes, I would check your static battery voltage, then check the charging system voltage once you get it running.
Once you find your short, then the codes will have to be cleared.
