John deere 319e remote start no working.
Lsaconroe87
texas
So I have 319e that when it reverse the machine made a loud noise and I lost forward and reverse. When I went to turn machine off, and tried to turn it back on it the lights would just flash and turn right off. I checked for active codes and got this at the menu, ECU 522597.09. Also the pictures below as well.
mg2361
Pennsylvania
Equipment Mechanic
First, complete machine serial numbers are a must for accurate information gathering, so please post up the S/N.
Is that code active? Stored? That code indicates a loss of communication from the ECU. Fuses good? The little red wire at the battery positive post securely attached to the positive battery clamp?
Lsaconroe87
texas
1T0319EJCEJ263415
The code is an active code. I did check all the fuses. The fuses were all good. I did check the battery but there was not a little red wire at the terminal. I did find a black 12 guage wire from the alternator that looked like it was rubbing along the engine but no burn marks. I did include two pictures with more code after I plugged in with my computer.
Lsaconroe87
texas
Before all this was happening. The machine was having throttle pedal issues and as well as the manual throttle knob. The machine would only throttle up on its own.
mg2361
Pennsylvania
Equipment Mechanic
Your title says remote start not working. Do you have the remote start box and it is not working?
Lsaconroe87
texas
Yes the remote start box is not working as well. It lights up like it's sending signal to starter and then shuts off.
mg2361
Pennsylvania
Equipment Mechanic
All the grounds and cables been thoroughly checked?
Can you post a video of lights in question showing the issue?
