TXGeoSolarPro
I have a JD 310G with a severe stabilzer drift. I performed the test for leakage and the manual specifies .6oz leakage per minute when operating the control, fluid literally sprays across the shop. I am moderately mechanically able, have replaced the engine in a previous hoe, taken tracks off dozers and excavators and have the reference manual but am a little apprehensive about changing the seals in the cylinders...probably since I have never done it or seen it done. The JD dealer quoted a price where I could almost buy two overhauled cylinders for what they want to rebuild mine. My concerns are proper placement of the filler ring so that the inner snap ring doesn't catch in the groove, installation of the seal ring on the piston (instructions state to place it in warm water but then it needs to be shrunk once on the piston) and reassembly of the parts once all new seals are in place. Can anyone give me any advise? Also, the JD dealer wants to replace the piston regardless of wear on the formed in place bearings. The repair manual advises the piston only needs replaced if the piston bearings show signs of wear or have nicks or cuts.
