red68racer
he.llo everyone
i went bought a as is john deere 310a backhoe , hired rollback , hit a bridge cause overheight , blew tire out on rollback , and had to pay guy with rollback more money put battery in , new switch , wire to injection pump , sprayed wd40 down in intake and let set 24 hrs , then
went to crank , nothing , no fuel to injectiors , mechanical pump bad , replaced with facet low pressure pump , still no fuel , pulled top of injector pump off , solniod working , took pump off and carried to rebuild local shop. today sprayed whole machine purple power , pressured washed ,lots of grease /oil/yellow paint , then i seen bell housing cracked behind engine ,looked recent , hitting a bridge not good !!! from top to about halfway down .
so the fun has started , need housing used ?plus check clutch disc /pressure plate ,etc? was told from helper trans was strating to slip from helper b bought it from .
